Deletes mirror source filters for an instance.
| mirror_name | Specifies the mirror's name. |
| port | Specifies a port or a slot and port. |
| port | Specifies particular ports or slots and ports. |
| ip-fix | Disables mirroring packets of IPFIX flows. |
| vlan | Specifies a VLAN. |
| vlan_id | Specifies a VLAN ID. |
| name | Specifies a VLAN name. |
N/A.
The following example deletes the mirroring filter on port 1:
configure mirroring delete ports 1
The VLAN option was added in ExtremeXOS 11.0.
The vlan_id option was added in ExtremeXOS 16.1.
